Salta al contenuto principale
Introduzione
Before use underwater it's important to ensure that the device is properly sealed. Otherwise, the device will likely be seriously damaged. If the battery/memory card cover seal is damaged, broken, or not properly sealing the device to prevent it from taking in water or other hazards, then it needs to be replaced before the camera is used underwater.
Ricambi
Nessuna parte specificata.
  1. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery: passo 1, immagine 1 di 2 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery: passo 1, immagine 2 di 2
    • Using your finger, slide the release catch to unlock the battery/memory card cover.
  2. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: passo 2, immagine 1 di 2 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: passo 2, immagine 2 di 2
    • Open the battery/memory card door.
  3. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: passo 3, immagine 1 di 2 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: passo 3, immagine 2 di 2
    • Push the battery eject lever to free the battery.
  4. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: passo 4, immagine 1 di 1
    • Remove the battery from the device.
  5. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery/Memory Card Door Seal: passo 5, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the two 2mm screws on the battery/memory card cover seal.
  6. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: passo 6, immagine 1 di 1
    • Using your fingers, remove the battery/memory card door seal.
Conclusione
3 Commenti
hi sir do you have battery lock for replacement ?
John Anthony Geronez - Replica
the Cyber shot by Sony has a lousy battery door it breaks very easily it's made of cheap plastic do you have any replacements for it?
SHELIAH HIPPS - Replica
Where can I get the door catch - is it still available?
sid123 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 24
Tutti i Tempi: 1,186
