Salta al contenuto principale
Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement
Cosa ti serve
  1. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery: passo 1, immagine 1 di 2 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery: passo 1, immagine 2 di 2
    • Using your finger, slide the release catch to unlock the battery/memory card cover.
  2. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: passo 2, immagine 1 di 2 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: passo 2, immagine 2 di 2
    • Open the battery/memory card door.
  3. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: passo 3, immagine 1 di 2 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: passo 3, immagine 2 di 2
    • Push the battery eject lever to free the battery.
  4. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: passo 4, immagine 1 di 1
    • Remove the battery from the device.
  5. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery/Memory Card Door Seal: passo 5, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the two 2mm screws on the battery/memory card cover seal.
  6. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: passo 6, immagine 1 di 1
    • Using your fingers, remove the battery/memory card door seal.
Conclusione
3 Commenti
hi sir do you have battery lock for replacement ?
John Anthony Geronez - Replica
the Cyber shot by Sony has a lousy battery door it breaks very easily it's made of cheap plastic do you have any replacements for it?
SHELIAH HIPPS - Replica
Where can I get the door catch - is it still available?
sid123 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 38
Tutti i Tempi: 1,735
