Introduzione
When removing the Sony Cyber-Shot DSC-S90 LCD display, it’s important to know when replacing or dissembling the overall display, it is one of the few processes that required disassembly of the majority of the camera. You will need a total of two tools consisting of the plastic opening tool, and the J00 screwdriver. This is a moderately difficult step, but may take more time than anticipated.
Cosa ti serve
Hold down the "open"button (gray oval with arrow pointing upwards) on the battery port door.
While holding the button downwards, slide the door upwards to unlock and open the door.
Remove the 2mm Phillips #00 screw under the battery port door.
Remove the 2mm Phillips #00 screw towards the right of the bottom-side of the camera.
Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the top of the camera.
Release all clips and latches keeping the casing in place using a spudger, opening tool, or screwdriver.
Disconnect the ribbon cables on top of the battery terminal using a spudger or screwdriver.
Disconnect the three pictured ribbon cables using a spudger or screwdriver.
Unlatch the two clips holding the LCD display onto the main camera housing using a spudger.
