Introduzione
Removing the Sony Cyber-Shot DSC-S90 battery terminal is considered to be a moderately difficult process. This is because through the process of removing the battery terminal, the disassembly of almost the entire camera is required. Despite the enhancement of difficulty in this 15 step guide, the only tool needed is the J00 screwdriver.
Cosa ti serve
Hold down the "open"button (gray oval with arrow pointing upwards) on the battery port door.
While holding the button downwards, slide the door upwards to unlock and open the door.
Remove the 2mm Phillips #00 screw under the battery port door.
Remove the 2mm Phillips #00 screw towards the right of the bottom-side of the camera.
Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the top of the camera.
Release all clips and latches keeping the casing in place using a spudger, opening tool, or screwdriver.
Disconnect the ribbon cables on top of the battery terminal using a spudger or screwdriver.
