Introduzione
If the camera lens is unrepairable, you may just need to replace it with a brand new one. This is how you take it apart before you insert a new one.
Cosa ti serve
Take a hold of the right side of the LCD screen and lift it towards the left.
Using a Phillips #0 screwdriver, unscrew the four 4.24 mm black screws off the blue panel on the right side.
Disconnect the white conductive tape.
Remove the blue panel.
Use tweezers to remove the three conductive tape strips on the right side.
Altre 3 persone hanno completato questa guida.
