Salta al contenuto principale
Sony Cyber-Shot DSC-H1 LCD Screen Replacement
Cosa ti serve
  1. Sony Cyber-Shot DSC-H1 LCD Screen Replacement, Back Panel: passo 1, immagine 1 di 1
    • Power down the camera and remove the batteries.
  2. Sony Cyber-Shot DSC-H1 LCD Screen Replacement: passo 2, immagine 1 di 3 Sony Cyber-Shot DSC-H1 LCD Screen Replacement: passo 2, immagine 2 di 3 Sony Cyber-Shot DSC-H1 LCD Screen Replacement: passo 2, immagine 3 di 3
    • Using a Phillips #0 screwdriver, remove all of the screws from the back panel casing.
    • There are six 5.22mm long, 3.00mm head diameter screws total.
    • The left side is not shown but there should be 1 screw on that side.
  3. Sony Cyber-Shot DSC-H1 LCD Screen Replacement: passo 3, immagine 1 di 2 Sony Cyber-Shot DSC-H1 LCD Screen Replacement: passo 3, immagine 2 di 2
    • Remove the back casing.
    • The casing itself is sturdy so don't be afraid to remove it forcefully.
  4. Sony Cyber-Shot DSC-H1 LCD Screen Replacement, LCD Screen: passo 4, immagine 1 di 1
    • Take a hold of the right side of the LCD screen and lift it towards the left.
    • The screen is held firm and will require a bit of force to ease it from its housing.
  5. Sony Cyber-Shot DSC-H1 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Unplug the large conductive tape attached to the screen.
    • Remove the LCD from the device.
Conclusione
Baylor, Team S5-G4, Williams Spring 2018 Membro di Baylor, Team S5-G4, Williams Spring 2018
BU-WILLIAMS-S18S5G4
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 743
