Introduzione
The following guidelines will show the step-by-step procedure on how to remove and replace the Sony Clie thumb dial.
Parti
Nessuna parte richiesta.
  1. First, place the device with the screen side facing down. Remove the 2 screws from the thumb dial panel located on the upper right hand side.
    • First, place the device with the screen side facing down. Remove the 2 screws from the thumb dial panel located on the upper right hand side.
  2. Remove the screw  directly above the thumb dial panel.
    • Remove the screw directly above the thumb dial panel.
    • Remove the screw from thumb dial panel on the right handed side of the device.
    • Remove screw from lower right side of the device.
    • Remove 1 screw from the lower left side of the device.
    • On the bottom of the device, remove both the left and right screws.
    • Remove the thumb dial panel by sliding it away from the device.
    • Remove the back panel exposing the inside of the device.
    • Locate thumb dial on top right side of the board.
    • Follow ribbon wire to locate where it plugs into the board. The plug is a flat black square.
    • Pull plug straight up to remove from board.
Conclusione
Rob
Membro da: 04/10/2011
1 Reputazione
2 Guide realizzate
UW Stout, Team 5-6, Zhou Fall 2011 Membro di UW Stout, Team 5-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G6
4 Membri
2 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 941
