Introduzione
This article will teach the user how to remove an old battery from a Sony Clie PEG-T615C with short and easy-to-follow steps.
Parti
Nessuna parte richiesta.
  1. Remove two screws from the thumb dial panel on the back of the device.
    • Remove two screws from the thumb dial panel on the back of the device.
  2. Remove one screw from the upper right corner on the back of the device.
    • Remove one screw from the upper right corner on the back of the device.
    • Remove one screw from the thumb dial panel on the right side of the device.
    • Remove one screw from lower right side of the device.
    • Remove one screw from the lower left side of the device.
    • Remove two screws from the bottom of the device.
    • Remove the thumb dial panel by sliding it away from the device.
    • You can do this step earlier, after you remove all of the screws from the thumb drive panel.
    • Remove the back panel, exposing the inside of the device.
    • Remove one screw located on the board below the battery.
    • Unplug the male battery plug on the battery wire from the female battery plug on the board.
    • Remove the battery by sliding it out of the side of the device.
Conclusione
Rob
Membro da: 04/10/2011
1 Reputazione
2 Guide realizzate
UW Stout, Team 5-6, Zhou Fall 2011 Membro di UW Stout, Team 5-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G6
4 Membri
2 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,526
