Introduzione
Installing a new speaker fairly simple as it only involves opening the device casing and then removing the broken speaker.
Parti
Nessuna parte richiesta.
Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
  • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
  • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
Aggiungi Commento
Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
Aggiungi Commento
  • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
  • Remove the back panel by lifting it away with your hands.
Aggiungi Commento
  • Use tweezers to unplug the speaker wire from the motherboard by pulling the plug (not the wires) down towards the speaker.
  • Be careful not to tear the speaker wires! They are very thin.
  • Remove the tape holding speaker wire by peeling it away.
Aggiungi Commento
  • Holding down the speaker rail unscrew the two 2.5mm screws with a Phillips #00 screwdriver.
  • Remove the speaker rail vertically from the device.
Aggiungi Commento
  • Hold back the plastic tabs to pop the speaker out of the rail.
Aggiungi Commento
Conclusione
Daniel Soski
Membro da: 18/04/2013
20 Reputazione
6 Guide realizzate
Cal Poly, Team 14-11, Maness Spring 2013 Membro di Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 185
