Introduzione
Installing a new motherboard involves removing the other components. Once this is done, removing the motherboard involves unscrewing the board from the housing and disconnecting various cables and wires.
Parti
Nessuna parte richiesta.
Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
  • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
  • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
Aggiungi Commento
Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
Aggiungi Commento
  • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
  • Remove the back panel by lifting it away with your hands.
Aggiungi Commento
  • Pull up on the black tab on the battery pack to reveal the power cord.
Aggiungi Commento
  • Disconnect the battery pack from the motherboard by unplugging the power cables. Gently pull the wire toward the bottom of the device.
  • Be careful to not tear the cables! They are very thin.
Aggiungi Commento
  • Gently peel back the adhesive to completely disconnect the battery pack from device.
Aggiungi Commento
  • Holding the memory module in place, unscrew the three 0.9mm screws with a Phillips #00 screwdriver.
Aggiungi Commento
  • Lightly grab the memory module and pull it upwards.
  • Make sure you grab the end closest to the edge of the device. You may have to wiggle the module a bit to get it to come free.
Aggiungi Commento
  • Unscrew the 2.5mm screw on the top portion of the audio module with a Phillips #00 screwdriver.
Aggiungi Commento
  • Remove the tape that is holding the module down.
Aggiungi Commento
  • Lift up the orange ribbon cable and unscrew the two 2.5mm screws located at the corners of the audio module with a Phillips #00 screwdriver.
Aggiungi Commento
  • Unplug the audio module from the motherboard by disconnecting the wires by lifting the orange wire up.
Aggiungi Commento
  • Use tweezers to unplug the speaker wire from the motherboard by pulling the plug (not the wires) down towards the speaker.
  • Be careful not to tear the speaker wires! They are very thin.
  • Remove the tape holding speaker wire by peeling it away.
Aggiungi Commento
  • Holding down the speaker rail unscrew the two 2.5mm screws with a Phillips #00 screwdriver.
  • Remove the speaker rail vertically from the device.
Aggiungi Commento
  • Unplug the ribbon cable found near the bottom of the motherboard by pulling it towards the bottom of the device.
  • Be careful not to tear the plug! It is very thin.
Aggiungi Commento
  • Unplug the ribbon cable connected at the bottom of the memory module by prying it up with a spudger.
Aggiungi Commento
  • Unplug the wires found underneath the right side of the "stem" of the motherboard by pulling gently.
  • Be careful not to tear the wires! They are very thin.
Aggiungi Commento
  • Lift up the black locking tab holding the ribbon cable in place.
  • Gently pull on the ribbon cable to remove it from the ZIF connector.
  • Be careful not to tear the ribbon cable! It is very thin.
Aggiungi Commento
  • Unplug the yellow connector from the underside of the left side of the motherboard by pulling gently.
Aggiungi Commento
  • Unplug the second yellow connector from the underside of the right side of the motherboard by pulling gently.
Aggiungi Commento
  • Unplug the last set of wires from underneath the top of the motherboard.
  • The motherboard should be loose now. You should be able to wiggle it free from the housing.
Aggiungi Commento
Conclusione
Daniel Soski
Membro da: 18/04/2013
20 Reputazione
6 Guide realizzate
Cal Poly, Team 14-11, Maness Spring 2013 Membro di Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 395
