Introduzione
If your device is not holding a charge or simply will not turn on, it is possible that you need to replace the battery. This easy guide will take you through the necessary steps in order to remove the battery so you may install a new one.
Cosa ti serve
Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
Pull up on the black tab on the battery pack to reveal the power cord.
Altre 3 persone hanno completato questa guida.
