Salta al contenuto principale
Sony CPF-IP001 Subwoofer Replacement
Cosa ti serve
  1. Sony CPF-IP001 Subwoofer Replacement, Subwoofer Housing Disassembly: passo 1, immagine 1 di 2 Sony CPF-IP001 Subwoofer Replacement, Subwoofer Housing Disassembly: passo 1, immagine 2 di 2
    • Remove fourteen 8 mm Phillips #2 screws from the bottom of the subwoofer.
    • Once all of the screws are removed, the cover can be taken off using a metal spudger.
  2. Sony CPF-IP001 Subwoofer Replacement: passo 2, immagine 1 di 2 Sony CPF-IP001 Subwoofer Replacement: passo 2, immagine 2 di 2
    • Remove eight 14 mm Phillips #2 screws holding the circuit board in place.
    • Using the plastic opening tool, carefully remove the circuit board.
    • There will be 3 wires connected to the opposite side of the circuit board. Be careful not to pull the board out of the device too far and damage these wires.
  3. Sony CPF-IP001 Subwoofer Replacement: passo 3, immagine 1 di 2 Sony CPF-IP001 Subwoofer Replacement: passo 3, immagine 2 di 2
    • Remove the first of the three wires by squeezing the clip and pulling it out.
    • After disconnecting the first wire, the two attached wires can be more easily accessed.
  4. Sony CPF-IP001 Subwoofer Replacement: passo 4, immagine 1 di 3 Sony CPF-IP001 Subwoofer Replacement: passo 4, immagine 2 di 3 Sony CPF-IP001 Subwoofer Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the wire furthest to the left by squeezing the clip and pulling it out.
    • Detach the third wire by carefully using the tweezers.
    • The circuit board is now completely detached and can be set aside.
  5. Sony CPF-IP001 Subwoofer Replacement: passo 5, immagine 1 di 2 Sony CPF-IP001 Subwoofer Replacement: passo 5, immagine 2 di 2
    • Remove six 8 mm Phillips #2 screws.
    • Slide the side panel with the power cord out from the housing.
    • The side panel with the power cord will come out as a whole unit with the subwoofer air tunnel.
  6. Sony CPF-IP001 Subwoofer Replacement, Subwoofer: passo 6, immagine 1 di 1
    • Remove two 8 mm Phillips #2 screws holding the side panel in place.
  7. Sony CPF-IP001 Subwoofer Replacement: passo 7, immagine 1 di 1
    • Remove eight 8 mm Phillips #2 screws holding the subwoofer tray to the housing.
  8. Sony CPF-IP001 Subwoofer Replacement: passo 8, immagine 1 di 2 Sony CPF-IP001 Subwoofer Replacement: passo 8, immagine 2 di 2
    • Using a metal spudger, slightly peel back the plastic the has been glued to the tray and the housing.
    • Slide the tray containing the subwoofer out of the housing.
  9. Sony CPF-IP001 Subwoofer Replacement: passo 9, immagine 1 di 2 Sony CPF-IP001 Subwoofer Replacement: passo 9, immagine 2 di 2
    • After removing the tray, flip it over and you will find four screws connecting the subwoofer.
    • Remove four 7.5 mm Phillips #2 screws.
  10. Sony CPF-IP001 Subwoofer Replacement: passo 10, immagine 1 di 2 Sony CPF-IP001 Subwoofer Replacement: passo 10, immagine 2 di 2
    • The subwoofer has now been removed from the device and can be replaced.
Conclusione
Altre 3 persone hanno completato questa guida.
Mike Bolton
Membro da: 04/14/15
473 Reputazione
4 Guide realizzate
Cal Poly, Team 6-14, Maness Spring 2015 Membro di Cal Poly, Team 6-14, Maness Spring 2015
CPSU-MANESS-S15S6G14
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 745
