Salta al contenuto principale
Sony CPF-IP001 Subwoofer Replacement
Cosa ti serve
    1. Sony CPF-IP001 Subwoofer Replacement, Subwoofer Housing Disassembly: passo 1, immagine 1 di 2 Sony CPF-IP001 Subwoofer Replacement, Subwoofer Housing Disassembly: passo 1, immagine 2 di 2
      • Remove fourteen 8 mm Phillips #2 screws from the bottom of the subwoofer.
      • Once all of the screws are removed, the cover can be taken off using a metal spudger.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony CPF-IP001 Subwoofer Replacement: passo 2, immagine 1 di 2 Sony CPF-IP001 Subwoofer Replacement: passo 2, immagine 2 di 2
      • Remove eight 14 mm Phillips #2 screws holding the circuit board in place.
      • Using the plastic opening tool, carefully remove the circuit board.
      • There will be 3 wires connected to the opposite side of the circuit board. Be careful not to pull the board out of the device too far and damage these wires.
      Chiedi a FixBot
      Aggiungi Commento
    3. Sony CPF-IP001 Subwoofer Replacement: passo 3, immagine 1 di 2 Sony CPF-IP001 Subwoofer Replacement: passo 3, immagine 2 di 2
      • Remove the first of the three wires by squeezing the clip and pulling it out.
      • After disconnecting the first wire, the two attached wires can be more easily accessed.
      Chiedi a FixBot
      Aggiungi Commento
    4. Sony CPF-IP001 Subwoofer Replacement: passo 4, immagine 1 di 3 Sony CPF-IP001 Subwoofer Replacement: passo 4, immagine 2 di 3 Sony CPF-IP001 Subwoofer Replacement: passo 4, immagine 3 di 3
      Strumento utilizzato in questo passaggio:
      • Remove the wire furthest to the left by squeezing the clip and pulling it out.
      • Detach the third wire by carefully using the tweezers.
      • The circuit board is now completely detached and can be set aside.
      Chiedi a FixBot
      Aggiungi Commento
    5. Sony CPF-IP001 Subwoofer Replacement: passo 5, immagine 1 di 2 Sony CPF-IP001 Subwoofer Replacement: passo 5, immagine 2 di 2
      • Remove six 8 mm Phillips #2 screws.
      • Slide the side panel with the power cord out from the housing.
      • The side panel with the power cord will come out as a whole unit with the subwoofer air tunnel.
      Chiedi a FixBot
      Aggiungi Commento
    1. Sony CPF-IP001 Subwoofer Replacement, Subwoofer: passo 6, immagine 1 di 1
      • Remove two 8 mm Phillips #2 screws holding the side panel in place.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony CPF-IP001 Subwoofer Replacement: passo 7, immagine 1 di 1
      • Remove eight 8 mm Phillips #2 screws holding the subwoofer tray to the housing.
      Chiedi a FixBot
      Aggiungi Commento
    3. Sony CPF-IP001 Subwoofer Replacement: passo 8, immagine 1 di 2 Sony CPF-IP001 Subwoofer Replacement: passo 8, immagine 2 di 2
      • Using a metal spudger, slightly peel back the plastic the has been glued to the tray and the housing.
      • Slide the tray containing the subwoofer out of the housing.
      Chiedi a FixBot
      Aggiungi Commento
    4. Sony CPF-IP001 Subwoofer Replacement: passo 9, immagine 1 di 2 Sony CPF-IP001 Subwoofer Replacement: passo 9, immagine 2 di 2
      • After removing the tray, flip it over and you will find four screws connecting the subwoofer.
      • Remove four 7.5 mm Phillips #2 screws.
      Chiedi a FixBot
      Aggiungi Commento
    5. Sony CPF-IP001 Subwoofer Replacement: passo 10, immagine 1 di 2 Sony CPF-IP001 Subwoofer Replacement: passo 10, immagine 2 di 2
      • The subwoofer has now been removed from the device and can be replaced.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Mike Bolton
Membro da: 04/14/15
473 Reputazione
4 guide realizzate
Cal Poly, Team 6-14, Maness Spring 2015 Membro di Cal Poly, Team 6-14, Maness Spring 2015
CPSU-MANESS-S15S6G14
4 Membri
24 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 10
Ultimi 30 giorni: 41
Tutti i Tempi: 1,169
