Salta al contenuto principale
Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement
Cosa ti serve
  1. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Batteries: passo 1, immagine 1 di 1
    • Press down on the two tabs at the top of the door.
    • Rotate the door away from the radio, towards you.
    • Lift the door out of the three smaller tabs on the bottom.
    • Ensure the radio is turned off to avoid the possibility of electric shock.
    • The battery compartment door is not shown.
  2. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Batteries: passo 2, immagine 1 di 3 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Batteries: passo 2, immagine 2 di 3 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Batteries: passo 2, immagine 3 di 3
    • Push the batteries against the spring and pull out using your finger to remove them.
    • To insert the new batteries, push the negative end of the 1st battery against a spring and follow the diagram pictured to insert the batteries in the correct orientation.
  3. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Screws: passo 3, immagine 1 di 3 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Screws: passo 3, immagine 2 di 3 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Screws: passo 3, immagine 3 di 3
    • Remove the 6 screws (30 mm in length) with the Phillips #2 Screwdriver from the large holes marked by arrows on the radio.
  4. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Opening: passo 4, immagine 1 di 1
    • Press the EJECT button to open the cassette deck.
    • Pressing this button is required to allow the front face to separate from the case.
  5. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement: passo 5, immagine 1 di 2 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement: passo 5, immagine 2 di 2
    • Grasp the radio from the front and back halves and gently pull apart to separate them.
  6. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement: passo 6, immagine 1 di 2 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement: passo 6, immagine 2 di 2
    • Pull the white plug out from the red outlet in the Orange circuit board in the back face of the casing.
    • Take care not to break the red outlet off the circuit board.
    • The front and back portions of the casing are now separated from each other.
  7. Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Volume or Tone Knob: passo 7, immagine 1 di 2 Sony CFS-204 Radio Cassette-Corder Volume Knob Replacement, Volume or Tone Knob: passo 7, immagine 2 di 2
    • Push upwards against bottom edge of the knob connection with a flat head screwdriver until the knob pops off.
    • You may wish to hold on to the knob so you don't lose it!
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,986
