Salta al contenuto principale
Sony CFS-204 Radio Cassette-Corder Batteries Replacement
Cosa ti serve
  1. Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: passo 1, immagine 1 di 1
    • Press down on the two tabs at the top of the door.
    • Rotate the door away from the radio, towards you.
    • Lift the door out of the three smaller tabs on the bottom.
    • Ensure the radio is turned off to avoid the possibility of electric shock.
    • The battery compartment door is not shown.
  2. Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: passo 2, immagine 1 di 3 Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: passo 2, immagine 2 di 3 Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: passo 2, immagine 3 di 3
    • Push the batteries against the spring and pull out using your finger to remove them.
    • To insert the new batteries, push the negative end of the 1st battery against a spring and follow the diagram pictured to insert the batteries in the correct orientation.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,938
