Salta al contenuto principale
Sony CFD-8 Battery Replacement
  1. Sony CFD-8 Battery Replacement, Battery: passo 1, immagine 1 di 3 Sony CFD-8 Battery Replacement, Battery: passo 1, immagine 2 di 3 Sony CFD-8 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
    • Be sure to unplug the boombox from the wall before attempting to open it for repair.
  2. Sony CFD-8 Battery Replacement: passo 2, immagine 1 di 2 Sony CFD-8 Battery Replacement: passo 2, immagine 2 di 2
    • Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries.
    • The top row of batteries have the positive side pointing right. The bottom row of batteries have the positive side pointing left.
Conclusione
Tess
Membro da: 10/14/14
439 Reputazione
2 Guide realizzate
Cal Poly, Team 10-38, Amido Fall 2014 Membro di Cal Poly, Team 10-38, Amido Fall 2014
CPSU-AMIDO-F14S10G38
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,062
