Introduzione
If buttons get stuck or you need to make any other type of replacement to the hardware of the video camera, you must first remove the outer case. This guide shows how all of the outer casing is removed, which involves removing extensive amounts of screws. To complete the case disassembly, the audio inputs are also removed from the video camera.
Cosa ti serve
Open the cassette cover.
Unscrew 14 screws located on the outer casing. Three are located on the top face 2x6.8mm and 1X4.54mm, three on the left face 1x4.54mm,1x5.3mm and seven on the bottom face 5x4.54mm and 2x6.77mm.
