Salta al contenuto principale
Sony Bloggie 3D Player USB Drive Replacement
Cosa ti serve
  1. Sony Bloggie 3D Player USB Drive Replacement, Front Cover: passo 1, immagine 1 di 1
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Sony Bloggie 3D Player USB Drive Replacement: passo 2, immagine 1 di 2 Sony Bloggie 3D Player USB Drive Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Sony Bloggie 3D Player USB Drive Replacement, Back Cover: passo 3, immagine 1 di 2 Sony Bloggie 3D Player USB Drive Replacement, Back Cover: passo 3, immagine 2 di 2
    • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
  4. Sony Bloggie 3D Player USB Drive Replacement: passo 4, immagine 1 di 2 Sony Bloggie 3D Player USB Drive Replacement: passo 4, immagine 2 di 2
    • Use a plastic opening tool to loosen the back cover off the device.
    • Once the back cover is loose, remove it gently by hand.
  5. Sony Bloggie 3D Player USB Drive Replacement, USB Drive: passo 5, immagine 1 di 2 Sony Bloggie 3D Player USB Drive Replacement, USB Drive: passo 5, immagine 2 di 2
    • Once the back cover is removed, by using the opening tool, remove the following screws using a Phillips #00 screwdriver.
    • Two 4.0mm Phillips #00 screws
    • One 8.0mm Phillips #00 screw
    • One 9.5mm Phillips #00 screw
  6. Sony Bloggie 3D Player USB Drive Replacement: passo 6, immagine 1 di 2 Sony Bloggie 3D Player USB Drive Replacement: passo 6, immagine 2 di 2
    • Using a spudger, remove the clips of the metal casing from each end of the USB drive.
  7. Sony Bloggie 3D Player USB Drive Replacement: passo 7, immagine 1 di 2 Sony Bloggie 3D Player USB Drive Replacement: passo 7, immagine 2 di 2
    • Carefully lift the USB drive off of the peg that it is attached to.
  8. Sony Bloggie 3D Player USB Drive Replacement: passo 8, immagine 1 di 1
    • Now that the USB component is on its own, untangle the ribbon from inside the device.
  9. Sony Bloggie 3D Player USB Drive Replacement: passo 9, immagine 1 di 1
    • Now remove the ZIF connector from the device using a pair of tweezers.
Conclusione
Craig Sweet
Membro da: 01/11/13
1 Reputazione
1 Guida realizzata
Cal Poly, Team 7-12, Maness Winter 2013 Membro di Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 486
