Salta al contenuto principale
Sony Bloggie 3D Player Main Button's Circuit Board Replacement
Cosa ti serve
  1. Sony Bloggie 3D Player Main Button's Circuit Board Replacement, Front Cover: passo 1, immagine 1 di 1
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Sony Bloggie 3D Player Main Button's Circuit Board Replacement: passo 2, immagine 1 di 2 Sony Bloggie 3D Player Main Button's Circuit Board Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Sony Bloggie 3D Player Main Button's Circuit Board Replacement, Main Button's Circuit Board: passo 3, immagine 1 di 2 Sony Bloggie 3D Player Main Button's Circuit Board Replacement, Main Button's Circuit Board: passo 3, immagine 2 di 2
    • Detach the board from the ZIF connector using a pair of tweezers or by hand.
    • Flip the circuit board over and remove the connector on the backside. Now you can safely remove the circuit board.
Conclusione
Robert Tam
Membro da: 01/30/13
6 Reputazione
2 Guide realizzate
Cal Poly, Team 7-12, Maness Winter 2013 Membro di Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 366
