Introduzione
Whether it's by dust or wear, the Main Button's Circuit Board can malfunction over time. This guide focuses on how to install a new Main Button's Circuit Board to get your device running like new.
Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
Aggiungi Commento
Use a plastic opening tool to pry the cover open.
  • Use a plastic opening tool to pry the cover open.
  • After the the cover is partly open as shown, remove the cover with your hands.
Aggiungi Commento
  • Detach the board from the ZIF connector using pair of tweezers or by hand.
  • Flip the circuit board over and remove the connector that is on the backside, now you can safely remove the circuit board.
Aggiungi Commento
Conclusione
Robert Tam
Membro da: 30/01/2013
6 Reputazione
2 Guide realizzate
Cal Poly, Team 7-12, Maness Winter 2013 Membro di Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 273
