Salta al contenuto principale
Sony Bloggie 3D Player Battery Replacement
Cosa ti serve
  1. Sony Bloggie 3D Player Battery Replacement, Front Cover: passo 1, immagine 1 di 1
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Sony Bloggie 3D Player Battery Replacement: passo 2, immagine 1 di 2 Sony Bloggie 3D Player Battery Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Sony Bloggie 3D Player Battery Replacement, Back Cover: passo 3, immagine 1 di 2 Sony Bloggie 3D Player Battery Replacement, Back Cover: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
  4. Sony Bloggie 3D Player Battery Replacement: passo 4, immagine 1 di 2 Sony Bloggie 3D Player Battery Replacement: passo 4, immagine 2 di 2
    • Use a plastic opening tool to loosen the back cover off the device.
    • Once the back cover is loose, remove it gently by hand.
  5. Sony Bloggie 3D Player Battery Replacement, Battery: passo 5, immagine 1 di 2 Sony Bloggie 3D Player Battery Replacement, Battery: passo 5, immagine 2 di 2
    • Remove the battery with your fingers.
Conclusione
Cal Poly, Team 7-12, Maness Winter 2013 Membro di Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 Membri
12 Guide realizzate
Un commento
You forgot to mention the need to flip the screen up (a screw holds it down) in order to get to a screw holding the back cover. Other than that, thank you for the info.
Rich Brewer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 2,177
