Salta al contenuto principale
Sony Betamovie BMC-220 Power Button Replacement
Cosa ti serve
  1. Sony Betamovie BMC-220 Power Button Replacement, Battery: passo 1, immagine 1 di 3 Sony Betamovie BMC-220 Power Button Replacement, Battery: passo 1, immagine 2 di 3 Sony Betamovie BMC-220 Power Button Replacement, Battery: passo 1, immagine 3 di 3
    • Orient your Betamovie so that the back of the device is sitting flat, and the bottom of the device is facing you.
    • Slide the RELEASE switch up to bring the hand drip down.
  2. Sony Betamovie BMC-220 Power Button Replacement: passo 2, immagine 1 di 3 Sony Betamovie BMC-220 Power Button Replacement: passo 2, immagine 2 di 3 Sony Betamovie BMC-220 Power Button Replacement: passo 2, immagine 3 di 3
    • Turn the BATTERY knob to OPEN, and open the lid.
    • Reminder: When inserting a new battery, make sure the knob is turned to OPEN.
    • Be careful not to point the hand grip down when turning the BATTERY knob. The battery pack may fall out.
  3. Sony Betamovie BMC-220 Power Button Replacement: passo 3, immagine 1 di 1
    • Remove the battery from the Betamovie.
  4. Sony Betamovie BMC-220 Power Button Replacement, Power Button: passo 4, immagine 1 di 3 Sony Betamovie BMC-220 Power Button Replacement, Power Button: passo 4, immagine 2 di 3 Sony Betamovie BMC-220 Power Button Replacement, Power Button: passo 4, immagine 3 di 3
    • Remove the two screws (2mm x 6mm) on either side of the FILTER switch on the black and white side of the Betamovie using the Phillips #0 screwdriver.
    • Remove the two screws on the bottom of the camera on the side with the black and white face using the same screwdriver.
    • Remove the screws on the bottom of the back of the camera with the same screwdriver.
  5. Sony Betamovie BMC-220 Power Button Replacement: passo 5, immagine 1 di 2 Sony Betamovie BMC-220 Power Button Replacement: passo 5, immagine 2 di 2
    • Remove the silver rectangular piece at the top of the Betamovie using your hands.
    • Remove the two screws (2mm x 6mm) under the flat silver piece using the Phillips #1 screwdriver. The silver metal clip comes off once the crews are removed.
  6. Sony Betamovie BMC-220 Power Button Replacement: passo 6, immagine 1 di 3 Sony Betamovie BMC-220 Power Button Replacement: passo 6, immagine 2 di 3 Sony Betamovie BMC-220 Power Button Replacement: passo 6, immagine 3 di 3
    • Remove the black and white cover from the Betamovie.
    • Remove the power button from the black and white face.
Conclusione
Jordan Bates
Membro da: 09/10/18
315 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 522
