Salta al contenuto principale
Sony BDP-S3700 Port Board Replacement
Cosa ti serve
  1. Sony BDP-S3700 Port Board Replacement, Front Panel: passo 1, immagine 1 di 2 Sony BDP-S3700 Port Board Replacement, Front Panel: passo 1, immagine 2 di 2
    • Use the PH1 screwdriver to remove the two 9mm screws on the back of the Blu-ray player.
  2. Sony BDP-S3700 Port Board Replacement: passo 2, immagine 1 di 2 Sony BDP-S3700 Port Board Replacement: passo 2, immagine 2 di 2
    • Remove the back of the device by slowly sliding the rear outer housing backwards.
  3. Sony BDP-S3700 Port Board Replacement: passo 3, immagine 1 di 2 Sony BDP-S3700 Port Board Replacement: passo 3, immagine 2 di 2
    • Turn the Blu-ray over
    • Pry open the clips under and on the sides
  4. Sony BDP-S3700 Port Board Replacement: passo 4, immagine 1 di 1
    • Once all the clips are open, slide the front outer housing out.
  5. Sony BDP-S3700 Port Board Replacement, Port Board: passo 5, immagine 1 di 1
    • Flip the Blu-ray back up
    • Remove the ribbon connecting the port board to the motherboard.
    • Handle the circuits only on its side.
  6. Sony BDP-S3700 Port Board Replacement: passo 6, immagine 1 di 1
    • Use the PH1 to remove the 7mm screw on the port board.
  7. Sony BDP-S3700 Port Board Replacement: passo 7, immagine 1 di 1
    • Remove the port board.
Conclusione
USF Tampa, Team 12-1, Eyestone Spring 2017 Membro di USF Tampa, Team 12-1, Eyestone Spring 2017
USFT-EYESTONE-S17S12G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,025
