Salta al contenuto principale
Sony BDP-S3700 Motherboard Replacement
Cosa ti serve
  1. Sony BDP-S3700 Motherboard Replacement, Front Panel: passo 1, immagine 1 di 2 Sony BDP-S3700 Motherboard Replacement, Front Panel: passo 1, immagine 2 di 2
    • Use the PH1 screwdriver to remove the two 9mm screws on the back of the Blu-ray player.
  2. Sony BDP-S3700 Motherboard Replacement: passo 2, immagine 1 di 2 Sony BDP-S3700 Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the back of the device by slowly sliding the rear outer housing backwards.
  3. Sony BDP-S3700 Motherboard Replacement: passo 3, immagine 1 di 2 Sony BDP-S3700 Motherboard Replacement: passo 3, immagine 2 di 2
    • Turn the Blu-ray over
    • Pry open the clips under and on the sides
  4. Sony BDP-S3700 Motherboard Replacement: passo 4, immagine 1 di 1
    • Once all the clips are open, slide the front outer housing out.
  5. Sony BDP-S3700 Motherboard Replacement, Disc Drive: passo 5, immagine 1 di 3 Sony BDP-S3700 Motherboard Replacement, Disc Drive: passo 5, immagine 2 di 3 Sony BDP-S3700 Motherboard Replacement, Disc Drive: passo 5, immagine 3 di 3
    • Flip the Blu-ray back up
    • Remove the three ribbon cables that connect the disc drive to the motherboard.
    • Handle the circuits only on its side.
  6. Sony BDP-S3700 Motherboard Replacement: passo 6, immagine 1 di 2 Sony BDP-S3700 Motherboard Replacement: passo 6, immagine 2 di 2
    • Use a PH1 screwdriver to unscrew both of the 7mm screws on the side of the disc reader.
  7. Sony BDP-S3700 Motherboard Replacement: passo 7, immagine 1 di 1
    • Gently slide the disc drive to the right and lift up to remove the disc drive from the body of the player.
  8. Sony BDP-S3700 Motherboard Replacement, Motherboard: passo 8, immagine 1 di 2 Sony BDP-S3700 Motherboard Replacement, Motherboard: passo 8, immagine 2 di 2
    • Gently pull upwards on the ribbon cables to disconnect the motherboard from the Wi-Fi module and port board.
  9. Sony BDP-S3700 Motherboard Replacement: passo 9, immagine 1 di 3 Sony BDP-S3700 Motherboard Replacement: passo 9, immagine 2 di 3 Sony BDP-S3700 Motherboard Replacement: passo 9, immagine 3 di 3
    • Remove the three 7mm screws along the motherboard using a PH1 screwdriver.
  10. Sony BDP-S3700 Motherboard Replacement: passo 10, immagine 1 di 3 Sony BDP-S3700 Motherboard Replacement: passo 10, immagine 2 di 3 Sony BDP-S3700 Motherboard Replacement: passo 10, immagine 3 di 3
    • Remove the 4mm screw above the HDMI port and the 9mm screw Digital Out port.
  11. Sony BDP-S3700 Motherboard Replacement: passo 11, immagine 1 di 1
    • Carefully lift and pull the motherboard forward to remove.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 12-1, Eyestone Spring 2017 Membro di USF Tampa, Team 12-1, Eyestone Spring 2017
USFT-EYESTONE-S17S12G1
4 Membri
5 Guide realizzate
2 Commenti
Thanks for the guide really good! Does anyone know where i can get a sony bdp-s3700 motherboard replacement?
James Durham - Replica
Same problem here.
Julian Robbins -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,435
