Salta al contenuto principale
Sony BDP-BX510 Outer Cover Replacement
Cosa ti serve
  1. Sony BDP-BX510 Outer Cover Replacement, Outer Cover: passo 1, immagine 1 di 1
    • Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
  2. Sony BDP-BX510 Outer Cover Replacement: passo 2, immagine 1 di 2 Sony BDP-BX510 Outer Cover Replacement: passo 2, immagine 2 di 2
    • To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
    • Apply slightly more pressure to the left side until it unhooks then unhook the right side.
    • Close the disk tray by pressing the eject button again, then power off the device and unplug it.
    • Do not use too much force to remove the tray cover as you may break it.
  3. Sony BDP-BX510 Outer Cover Replacement: passo 3, immagine 1 di 2 Sony BDP-BX510 Outer Cover Replacement: passo 3, immagine 2 di 2
    • Turn to the back of the device.
    • Remove the two 7mm Phillips #2 screws.
    • Slide the two plastic covers on both sides of the device towards the back of the device to remove them.
  4. Sony BDP-BX510 Outer Cover Replacement: passo 4, immagine 1 di 3 Sony BDP-BX510 Outer Cover Replacement: passo 4, immagine 2 di 3 Sony BDP-BX510 Outer Cover Replacement: passo 4, immagine 3 di 3
    • Turn the device so you can see the bottom.
    • Unclip the three black plastic clips on the bottom of the device.
    • Unclip one clip on each side of the device.
  5. Sony BDP-BX510 Outer Cover Replacement: passo 5, immagine 1 di 1
    • Slide the cover forward to remove.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 177
