Salta al contenuto principale
Sony BDP-BX510 Disk Reader Replacement
Cosa ti serve
  1. Sony BDP-BX510 Disk Reader Replacement, Outer Cover: passo 1, immagine 1 di 1
    • Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
  2. Sony BDP-BX510 Disk Reader Replacement: passo 2, immagine 1 di 2 Sony BDP-BX510 Disk Reader Replacement: passo 2, immagine 2 di 2
    • To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
    • Apply slightly more pressure to the left side until it unhooks then unhook the right side.
    • Close the disk tray by pressing the eject button again, then power off the device and unplug it.
    • Do not use too much force to remove the tray cover as you may break it.
  3. Sony BDP-BX510 Disk Reader Replacement: passo 3, immagine 1 di 2 Sony BDP-BX510 Disk Reader Replacement: passo 3, immagine 2 di 2
    • Turn to the back of the device.
    • Remove the two 7mm Phillips #2 screws.
    • Slide the two plastic covers on both sides of the device towards the back of the device to remove them.
  4. Sony BDP-BX510 Disk Reader Replacement: passo 4, immagine 1 di 3 Sony BDP-BX510 Disk Reader Replacement: passo 4, immagine 2 di 3 Sony BDP-BX510 Disk Reader Replacement: passo 4, immagine 3 di 3
    • Turn the device so you can see the bottom.
    • Unclip the three black plastic clips on the bottom of the device.
    • Unclip one clip on each side of the device.
  5. Sony BDP-BX510 Disk Reader Replacement: passo 5, immagine 1 di 1
    • Slide the cover forward to remove.
  6. Sony BDP-BX510 Disk Reader Replacement, Disk Tray: passo 6, immagine 1 di 2 Sony BDP-BX510 Disk Reader Replacement, Disk Tray: passo 6, immagine 2 di 2
    • Pull the medium-sized 9 pin ribbon cable and the small 5 pin ribbon cable out of their connector in the motherboard.
    • Using tweezers, lift the black tab on the connector of the large 45 pin connector on the motherboard.
    • Pull the large 45 pin ribbon cable out of the connector in the motherboard.
    • Be very careful. The goal is to slightly lift the pin connector, not to completely detach it. Do not forcibly pull.
  7. Sony BDP-BX510 Disk Reader Replacement: passo 7, immagine 1 di 1
    • Remove the 5mm Phillips #2 screw holding the metal brace above the disk tray.
    • Remove the two 5mm Phillips #2 screws that hold the disk tray to the metal case on the bottom.
  8. Sony BDP-BX510 Disk Reader Replacement: passo 8, immagine 1 di 3 Sony BDP-BX510 Disk Reader Replacement: passo 8, immagine 2 di 3 Sony BDP-BX510 Disk Reader Replacement: passo 8, immagine 3 di 3
    • Turn the device over to the backside.
    • Use tweezers or hands to take off the metal clasp for the metal brace near the center on the bottom of the device.
  9. Sony BDP-BX510 Disk Reader Replacement: passo 9, immagine 1 di 1
    • Remove the metal brace then remove the disk tray.
  10. Sony BDP-BX510 Disk Reader Replacement, Disk Reader: passo 10, immagine 1 di 3 Sony BDP-BX510 Disk Reader Replacement, Disk Reader: passo 10, immagine 2 di 3 Sony BDP-BX510 Disk Reader Replacement, Disk Reader: passo 10, immagine 3 di 3
    • Connect the three cables.
    • Plug the device in and press the eject button to open the disk tray.
    • Unplug the device.
    • Disconnect the three cables.
  11. Sony BDP-BX510 Disk Reader Replacement: passo 11, immagine 1 di 3 Sony BDP-BX510 Disk Reader Replacement: passo 11, immagine 2 di 3 Sony BDP-BX510 Disk Reader Replacement: passo 11, immagine 3 di 3
    • Locate and unclip the plastic clips on the sides of the disk tray using a metal spudger. There are two on each side of the disk tray.
    • Lift open and remove the top cover of the disk tray.
    • Remove the two 6mm Phillips #0 screws from the disk reader.
  12. Sony BDP-BX510 Disk Reader Replacement: passo 12, immagine 1 di 1
    • Using tweezers, lift the black tab on the connector of the large ribbon cable on the disk reader.
    • Pull the large ribbon cable out of the connector in the disk reader.
    • Do not forcibly pull out the large ribbon cable as you could damage it. Once the black tab is lifted it should come out easily.
  13. Sony BDP-BX510 Disk Reader Replacement: passo 13, immagine 1 di 3 Sony BDP-BX510 Disk Reader Replacement: passo 13, immagine 2 di 3 Sony BDP-BX510 Disk Reader Replacement: passo 13, immagine 3 di 3
    • Lift the disk reader carefully.
    • Do not lift the disk reader roughly as there is small cable attached to it.
    • Pull the small ribbon cable out of the disk reader.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 40
