Salta al contenuto principale
Sony BDP-6500 Disk Assembly Replacement
Cosa ti serve
  1. Sony BDP-6500 Disk Assembly Replacement, Disk Assembly: passo 1, immagine 1 di 2 Sony BDP-6500 Disk Assembly Replacement, Disk Assembly: passo 1, immagine 2 di 2
    • Turn the player around so that the back is facing you.
  2. Sony BDP-6500 Disk Assembly Replacement: passo 2, immagine 1 di 3 Sony BDP-6500 Disk Assembly Replacement: passo 2, immagine 2 di 3 Sony BDP-6500 Disk Assembly Replacement: passo 2, immagine 3 di 3
    • Remove the three Phillips #1 screws.
  3. Sony BDP-6500 Disk Assembly Replacement: passo 3, immagine 1 di 3 Sony BDP-6500 Disk Assembly Replacement: passo 3, immagine 2 di 3 Sony BDP-6500 Disk Assembly Replacement: passo 3, immagine 3 di 3
    • Remove the top cover by sliding it off.
  4. Sony BDP-6500 Disk Assembly Replacement: passo 4, immagine 1 di 3 Sony BDP-6500 Disk Assembly Replacement: passo 4, immagine 2 di 3 Sony BDP-6500 Disk Assembly Replacement: passo 4, immagine 3 di 3
    • Turn the player around so that it appears as shown.
  5. Sony BDP-6500 Disk Assembly Replacement: passo 5, immagine 1 di 3 Sony BDP-6500 Disk Assembly Replacement: passo 5, immagine 2 di 3 Sony BDP-6500 Disk Assembly Replacement: passo 5, immagine 3 di 3
    • Pull up the two tabs with a pair of plastic tweezers.
    • You can use any tool that will give you leverage to pull up the tabs. Alternatively, you can use your fingers, but it may be more difficult.
  6. Sony BDP-6500 Disk Assembly Replacement: passo 6, immagine 1 di 1
    • Slightly pull off the front cover.
    • You will only be able to partially remove the front cover at this point. Keep pulling off until you feel resistance from the other side.
  7. Sony BDP-6500 Disk Assembly Replacement: passo 7, immagine 1 di 3 Sony BDP-6500 Disk Assembly Replacement: passo 7, immagine 2 di 3 Sony BDP-6500 Disk Assembly Replacement: passo 7, immagine 3 di 3
    • Pull up the two tabs on the other side using a pair of tweezers.
    • Pull the front cover off.
  8. Sony BDP-6500 Disk Assembly Replacement: passo 8, immagine 1 di 1
    • Orient the player as shown.
  9. Sony BDP-6500 Disk Assembly Replacement: passo 9, immagine 1 di 3 Sony BDP-6500 Disk Assembly Replacement: passo 9, immagine 2 di 3 Sony BDP-6500 Disk Assembly Replacement: passo 9, immagine 3 di 3
    • Remove the two Phillips #1 screws using a screwdriver.
  10. Sony BDP-6500 Disk Assembly Replacement: passo 10, immagine 1 di 3 Sony BDP-6500 Disk Assembly Replacement: passo 10, immagine 2 di 3 Sony BDP-6500 Disk Assembly Replacement: passo 10, immagine 3 di 3
    • Pull the first of three ribbon wires out of its socket using your fingers.
    • You may experience significant resistance when pulling out each of the wires.
  11. Sony BDP-6500 Disk Assembly Replacement: passo 11, immagine 1 di 3 Sony BDP-6500 Disk Assembly Replacement: passo 11, immagine 2 di 3 Sony BDP-6500 Disk Assembly Replacement: passo 11, immagine 3 di 3
    • Pull the other two ribbon wires out of their sockets.
  12. Sony BDP-6500 Disk Assembly Replacement: passo 12, immagine 1 di 3 Sony BDP-6500 Disk Assembly Replacement: passo 12, immagine 2 di 3 Sony BDP-6500 Disk Assembly Replacement: passo 12, immagine 3 di 3
    • Lift up the right side of the disk assembly.
    • Slide the disk assembly to the right.
    • Lift up the disk assembly to remove it.
    • Do not open up the disk assembly once you remove it from the player. If opened, your eyes may be harmed by the laser radiation from the disk lens within.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 431
