Salta al contenuto principale
Sony BDP BX350 Wifi Card Replacement
Cosa ti serve
  1. Sony BDP BX350 Wifi Card Replacement, Control Board: passo 1, immagine 1 di 1
    • Remove the three 10mm Philips head screws on the back of the player.
  2. Sony BDP BX350 Wifi Card Replacement: passo 2, immagine 1 di 1
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
  3. Sony BDP BX350 Wifi Card Replacement: passo 3, immagine 1 di 1
    • Lift the tabs located on each side of the device to free the front cover. Begin separating the two covers from metal casing.
  4. Sony BDP BX350 Wifi Card Replacement: passo 4, immagine 1 di 1
    • Remove both covers.
  5. Sony BDP BX350 Wifi Card Replacement: passo 5, immagine 1 di 2 Sony BDP BX350 Wifi Card Replacement: passo 5, immagine 2 di 2
    • Do not bend or tear the ribbon cable.
    • Using the plastic tweezers, carefully remove the ribbon cable from the motherboard.
  6. Sony BDP BX350 Wifi Card Replacement: passo 6, immagine 1 di 1
    • Unscrew the one 5mm Phillips head screw from the front of the device board.
  7. Sony BDP BX350 Wifi Card Replacement: passo 7, immagine 1 di 2 Sony BDP BX350 Wifi Card Replacement: passo 7, immagine 2 di 2
    • Do not bend or tear ribbon cable.
    • Carefully separate the device control board from the metal casing.
  8. Sony BDP BX350 Wifi Card Replacement, Wifi Card: passo 8, immagine 1 di 2 Sony BDP BX350 Wifi Card Replacement, Wifi Card: passo 8, immagine 2 di 2
    • Remove 6mm Philips head screw from wifi board.
  9. Sony BDP BX350 Wifi Card Replacement: passo 9, immagine 1 di 1
    • Remove the ribbon cable from motherboard using a pair of tweezers.
  10. Sony BDP BX350 Wifi Card Replacement: passo 10, immagine 1 di 3 Sony BDP BX350 Wifi Card Replacement: passo 10, immagine 2 di 3 Sony BDP BX350 Wifi Card Replacement: passo 10, immagine 3 di 3
    • Carefully remove board and ribbon cables by pulling upwards then out to free it from the metal clips.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 260
