Salta al contenuto principale
Sony BDP BX350 Motherboard Replacement
Cosa ti serve
  1. Sony BDP BX350 Motherboard Replacement, Disc Assembly: passo 1, immagine 1 di 1
    • Remove the three 10mm Philips head screws on the back of the player.
  2. Sony BDP BX350 Motherboard Replacement: passo 2, immagine 1 di 1
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
  3. Sony BDP BX350 Motherboard Replacement: passo 3, immagine 1 di 1
    • Lift the tabs located on each side of the device to free the front cover. Begin to separate the front and metal back covers.
  4. Sony BDP BX350 Motherboard Replacement: passo 4, immagine 1 di 1
    • Completely separate the front cover and the metal back cover from the grey casing.
    • The inner components should all be completely exposed after opening.
  5. Sony BDP BX350 Motherboard Replacement: passo 5, immagine 1 di 1
    • Unscrew the two 8mm Philips head screws securing the disc assembly to the main casing.
  6. Sony BDP BX350 Motherboard Replacement: passo 6, immagine 1 di 1
    • Pull the disc assembly out from under the metal tabs on the main casing.
  7. Sony BDP BX350 Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove disc assembly.
  8. Sony BDP BX350 Motherboard Replacement, Motherboard: passo 8, immagine 1 di 2 Sony BDP BX350 Motherboard Replacement, Motherboard: passo 8, immagine 2 di 2
    • Do not bend or tear the ribbon cable.
    • Remove all five ribbon cables from the motherboard.
  9. Sony BDP BX350 Motherboard Replacement: passo 9, immagine 1 di 1
    • Unscrew 3mm Philips head HDMI screw from metal casing.
  10. Sony BDP BX350 Motherboard Replacement: passo 10, immagine 1 di 1
    • Unscrew the three 5mm Philips head screws from motherboard.
    • Separate the motherboard from the metal casing by pulling directly up. Use an opening tool if necessary.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 575
