Salta al contenuto principale
Sony Alpha a7s II Diopter Replacement
Cosa ti serve
  1. Sony Alpha a7s II Diopter Replacement, Diopter: passo 1, immagine 1 di 1
    • Orient your camera so that you are looking at the posterior portion.
  2. Sony Alpha a7s II Diopter Replacement: passo 2, immagine 1 di 1
    • Place each of your thumbs on the interior portions of the eyepiece cup, pressing down and pushing up.
  3. Sony Alpha a7s II Diopter Replacement: passo 3, immagine 1 di 1
    • Slide the eyepiece off by carefully pulling it upward.
    • Be careful not to come into contact with the viewfinder lens as the lens can be easily scratched.
  4. Sony Alpha a7s II Diopter Replacement: passo 4, immagine 1 di 1
    • Remove the screw from the middle of the diopter with the JIS #00 screwdriver.
  5. Sony Alpha a7s II Diopter Replacement: passo 5, immagine 1 di 1
    • Remove the diopter with your hands. If the diopter is at all stuck you can use the pointed tweezers to help aid in the removal process.
    • Be careful not to let fingers or tweezers come into contact with the viewfinder lens as the lens can be easily scratched.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 30
Tutti i Tempi: 2,060
