Salta al contenuto principale
Sony Alpha SLT-A55V Battery Replacement
Cosa ti serve
  1. Sony Alpha SLT-A55V Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the battery compartment on the bottom of the unit. Then, slide the latch down to open the cover.
  2. Sony Alpha SLT-A55V Battery Replacement: passo 2, immagine 1 di 1
    • Insert the new battery and close the compartment.
    • Most new lithium batteries are partially charged to improve shelf life. It is recommended to charge the battery after installation even if the indicator shows a full charge. Unlike nickel cadmium batteries, lithium batteries will provide better performance when charged to full capacity from a partial charge of 60%.
Conclusione
There you go, now you have a fully functional camera again. Do not forget to recharge the other battery to be prepared to repeat this guide.
IUPUI, Team 1-1, Wilson Fall 2015 Membro di IUPUI, Team 1-1, Wilson Fall 2015
IUPUI-WILSON-F15S1G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,547
