Salta al contenuto principale
Sony Alpha NEX-C3 Top Panel Replacement
Cosa ti serve
  1. Sony Alpha NEX-C3 Top Panel Replacement, Top Panel: passo 1, immagine 1 di 1
    • Turn the camera off by sliding the power switch.
  2. Sony Alpha NEX-C3 Top Panel Replacement: passo 2, immagine 1 di 1
    • Use a Phillips head 000 screwdriver to remove the 4.0mm screw inside the USB port.
  3. Sony Alpha NEX-C3 Top Panel Replacement: passo 3, immagine 1 di 1
    • Use a Phillips head 000 screwdriver to remove the one 4.0mm screw on the side opposite of the USB port near the shutter button.
  4. Sony Alpha NEX-C3 Top Panel Replacement: passo 4, immagine 1 di 2 Sony Alpha NEX-C3 Top Panel Replacement: passo 4, immagine 2 di 2
    • Open the flap at the top of the camera.
    • Use a Phillips head 000 screwdriver to remove the two 4.0mm screws inside.
  5. Sony Alpha NEX-C3 Top Panel Replacement: passo 5, immagine 1 di 1
    • Gently lift off the top panel with your hands.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 771
