Salta al contenuto principale
Sony Alpha NEX-C3 Lens Mount Replacement
Cosa ti serve
  1. Sony Alpha NEX-C3 Lens Mount Replacement, Lens Mount: passo 1, immagine 1 di 1
    • Turn the camera off by sliding the power switch.
  2. Sony Alpha NEX-C3 Lens Mount Replacement: passo 2, immagine 1 di 1
    • Use a Phillips head 000 screwdriver to remove the four 5.0mm screws on the E-mount.
  3. Sony Alpha NEX-C3 Lens Mount Replacement: passo 3, immagine 1 di 3 Sony Alpha NEX-C3 Lens Mount Replacement: passo 3, immagine 2 di 3 Sony Alpha NEX-C3 Lens Mount Replacement: passo 3, immagine 3 di 3
    • Press on the lens mount button with one hand.
    • With the other hand, grab and gently wiggle off the E-mount metal ring until its free.
    • Remove the plastic ring located under the metal ring.
    • Do not remove the thin metal piece behind the plastic ring.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 624
