Salta al contenuto principale
Sony Alpha NEX-C3 LCD Screen Replacement
Cosa ti serve
  1. Sony Alpha NEX-C3 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 1
    • Turn off the camera by sliding the power switch.
  2. Sony Alpha NEX-C3 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Tilt up the LCD screen.
  3. Sony Alpha NEX-C3 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Use a Phillips head 000 screwdriver to remove the two 2.0mm screws on the bottom of the LCD screen.
  4. Sony Alpha NEX-C3 LCD Screen Replacement: passo 4, immagine 1 di 3 Sony Alpha NEX-C3 LCD Screen Replacement: passo 4, immagine 2 di 3 Sony Alpha NEX-C3 LCD Screen Replacement: passo 4, immagine 3 di 3
    • Use a Phillips head 000 screwdriver to remove the two 1.0mm screws on the smaller backplate of the LCD screen that covers the ribbon cable.
    • The smaller backplate should easily come off. Put it to the side.
  5. Sony Alpha NEX-C3 LCD Screen Replacement: passo 5, immagine 1 di 2 Sony Alpha NEX-C3 LCD Screen Replacement: passo 5, immagine 2 di 2
    • Use a Phillips head 000 screwdriver to remove the two 1.0mm screws on the bigger backplate of the LCD.
  6. Sony Alpha NEX-C3 LCD Screen Replacement: passo 6, immagine 1 di 2 Sony Alpha NEX-C3 LCD Screen Replacement: passo 6, immagine 2 di 2
    • Using the plastic opening tool, remove the larger backplate from the LCD screen.
  7. Sony Alpha NEX-C3 LCD Screen Replacement: passo 7, immagine 1 di 1
    • With your hands, gently remove the black plastic piece on the backside of the LCD screen.
  8. Sony Alpha NEX-C3 LCD Screen Replacement: passo 8, immagine 1 di 3 Sony Alpha NEX-C3 LCD Screen Replacement: passo 8, immagine 2 di 3 Sony Alpha NEX-C3 LCD Screen Replacement: passo 8, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers, gently open the connector. It pivots open. Pull up and away on the ribbon cable connected to the motherboard, after which, the LCD screen should come off.
    • The motherboard ribbon cable has a specific connector.
  9. Sony Alpha NEX-C3 LCD Screen Replacement: passo 9, immagine 1 di 3 Sony Alpha NEX-C3 LCD Screen Replacement: passo 9, immagine 2 di 3 Sony Alpha NEX-C3 LCD Screen Replacement: passo 9, immagine 3 di 3
    • The screen is attached to a frame, via a thin strip of adhesive. Press gently on a corner of the backside of the screen, to detach it from the frame.
    • If your replacement screen did not come with it's own adhesive, carefully peel the original adhesive strip from the original screen, and apply it to the new screen.
  10. Sony Alpha NEX-C3 LCD Screen Replacement: passo 10, immagine 1 di 3 Sony Alpha NEX-C3 LCD Screen Replacement: passo 10, immagine 2 di 3 Sony Alpha NEX-C3 LCD Screen Replacement: passo 10, immagine 3 di 3
    • Insert the new screen in to the frame, ensuring the ribbon cable and copper tab are gently folded inwards within the frame, so they are not damaged.
    • Now you may re-assemble, working backwards from step 8.
    • Enjoy your new screen!
Conclusione
To reassemble your device, follow these instructions in reverse order. However, when installing the ribbon cable, the connector has a specific step. The connector has a tiny flap that clamps down onto the ribbon cable in order to make it secure.
2Commenti sulla guida
Sir, my unit has many lines that appear on the screen. However, the lcd glass is pristine & has no cracks. Which part is defective? Is the lcd mother board the culprit? Thank you.
Stevie B - Replica
Sorry this is probably a little late, but this may mean the ribbon cable for the lcd is damaged, or not properly connected! Follow the screen replacement guide until you have access to the ribbon cable. See if it's damaged or not inserted completely!
Jesse's Heckin' Tech -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 29
Tutti i Tempi: 3,065
