Salta al contenuto principale
Sony Alpha NEX-6 Lens Replacement
  1. Sony Alpha NEX-6 Lens Replacement, Finding the Release Button: passo 1, immagine 1 di 1
    • Turn the camera with the lens facing up.
    • Find the lens release button - located along the side of the silver lens mount.
  2. Sony Alpha NEX-6 Lens Replacement, Removing the Lens: passo 2, immagine 1 di 2 Sony Alpha NEX-6 Lens Replacement, Removing the Lens: passo 2, immagine 2 di 2
    • Press and hold the lens release button while rotating the lens counterclockwise.
    • Lift the lens when it is no longer attached to the camera.
    • To replace the lens, align the white dot on the lens with the white dot located on the silver lens mount. (See image two)
    • Insert the lens and rotate it clockwise until it is locked in place.
Conclusione
The procedure to disassemble this lens is different from reassembly. This guide encompasses both processes.
Altre 2 persone hanno completato questa guida.
Clayton Dale
Membro da: 01/20/15
1.040 Reputazione
7 Guide realizzate
USF Tampa, Team 11-2, Blackwell Winter 2015 Membro di USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,441
