Salta al contenuto principale
Sony Alpha NEX-6 Lens Mount Replacement
Cosa ti serve
  1. Sony Alpha NEX-6 Lens Mount Replacement, Finding the Release Button: passo 1, immagine 1 di 1
    • Turn the camera with the lens facing up.
    • Find the lens release button - located along the side of the silver lens mount.
  2. Sony Alpha NEX-6 Lens Mount Replacement, Removing the Lens: passo 2, immagine 1 di 2 Sony Alpha NEX-6 Lens Mount Replacement, Removing the Lens: passo 2, immagine 2 di 2
    • Press and hold the lens release button while rotating the lens counterclockwise.
    • Lift the lens when it is no longer attached to the camera.
    • To replace the lens, align the white dot on the lens with the white dot located on the silver lens mount. (See image two)
    • Insert the lens and rotate it clockwise until it is locked in place.
  3. Sony Alpha NEX-6 Lens Mount Replacement, Lens Mount: passo 3, immagine 1 di 1
    • While dealing with this guide, do not touch the delicate image sensor (the center rectangle encircled by the lens mount).
    • After removing the lens, you will come into contact with the lens mount. Start by unscrewing the four 3.5 mm Phillips #00 screws.
    • The outer lens mount ring can now be removed.
  4. Sony Alpha NEX-6 Lens Mount Replacement: passo 4, immagine 1 di 3 Sony Alpha NEX-6 Lens Mount Replacement: passo 4, immagine 2 di 3 Sony Alpha NEX-6 Lens Mount Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Pay attention to the positioning of the spacer rings for reassembly.
    • For the first (black) spacer ring, use the tweezers to gently pry the ring out of place.
    • Repeat this step for the second (silver) spacer ring.
    • The third image is what the camera should look like after all spacer rings are removed.
  5. Sony Alpha NEX-6 Lens Mount Replacement: passo 5, immagine 1 di 2 Sony Alpha NEX-6 Lens Mount Replacement: passo 5, immagine 2 di 2
    • To remove the inner lens mount ring, remove the two silver 2.0 mm Phillips #00 screws. This will complete the removal of the lens mount.
Conclusione
Altre 3 persone hanno completato questa guida.
Clayton Dale
Membro da: 01/20/15
1.067 Reputazione
7 Guide realizzate
USF Tampa, Team 11-2, Blackwell Winter 2015 Membro di USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,707
