Salta al contenuto principale
Sony Alpha NEX-6 Battery Replacement
Cosa ti serve
  1. Sony Alpha NEX-6 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
    • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
  2. Sony Alpha NEX-6 Battery Replacement: passo 2, immagine 1 di 1
    • Flip the camera upside-down and carefully place it on a flat surface.
    • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
    • Push the latch to the right to unlock the battery compartment. The door should flip upward.
  3. Sony Alpha NEX-6 Battery Replacement: passo 3, immagine 1 di 1
    • With the compartment open, locate a blue tab shown with spudger
    • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
Conclusione
Altre 2 persone hanno completato questa guida.
Clayton Dale
Membro da: 01/20/15
1.067 Reputazione
7 Guide realizzate
USF Tampa, Team 11-2, Blackwell Winter 2015 Membro di USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 Membri
14 Guide realizzate
3 Commenti
Battery Stuck
rustychinnis - Replica
Will not spring out. Any ideas?
Got it, battery damaged. Tapped on edge to remove battery
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,350
