Introduzione
This guide includes screws removal and a procedure for removing the back case. Follow the steps precisely to avoid breaking of plastic locking tabs.
Cosa ti serve
Turn the camera off by switching the power knob "OFF" text to the white selector dot.
Remove the two 3.5mm Phillips #00 screws that hold the back case - located inside the battery compartment.
Remove the two 3.5mm Phillips #00 screws that hold the back case - located on the bottom of the camera.
Remove the 3.5 mm Phillips #00 screw on the side of camera - located between the charging and HDMI ports.
Remove the 4.0 mm Phillips #00 screw on the side of the camera - located next to the WiFi sign.
Starting with the battery compartment gently begin to separate the back case front the camera.
Using a plastic opening tool, separate the bottom of the back case from the camera. Then proceed by separating the sides.
Gently lift the back case away from the camera an slide it down to completely remove the back case.
Altre 2 persone hanno completato questa guida.
3Commenti sulla guida
At {STEP 7} you will notice the last parts to release are the flash button / record button areas. This is particularly tricky.
The flash button release seems to be attached inside, so take care. In my case I did not remove the back case completely due to this.
The corner where the record button is requires extra force to slide down / pry out.
Re-assembly : Take note of these parts.
- the PLAY button flexible circuit has a small hole which fits into a pin on the back case. It is important to align this correctly or your play & AEL button may not function.
- The eye piece has a flexible circuit on its right side which tucks behind a small tab - take care this is not dislodged or it could be damaged when re assembling.
Can you please let me know how to replace the battery door? Thank you.
