Salta al contenuto principale
Sony Alpha NEX-5N Battery Replacement
  1. Sony Alpha NEX-5N Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Before operating on this device, be sure the device is turned off.
    • Turn the device off by switching the power knob to face the word "OFF".
  2. Sony Alpha NEX-5N Battery Replacement: passo 2, immagine 1 di 2 Sony Alpha NEX-5N Battery Replacement: passo 2, immagine 2 di 2
    • Flip the device upside-down and gently place it down on a flat surface.
    • Locate the battery compartment, which is indicated by a grooved latch.
    • Push the latch to the right so that the arrow is positioned above the word "Open". The door should then flip upward.
  3. Sony Alpha NEX-5N Battery Replacement: passo 3, immagine 1 di 2 Sony Alpha NEX-5N Battery Replacement: passo 3, immagine 2 di 2
    • With the battery compartment latch open, locate the lock lever.
    • Press the lock lever to the left. This will eject the camera battery.
Conclusione
Demi Deletang
Membro da: 09/28/15
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 36
Tutti i Tempi: 2,524
