Salta al contenuto principale
Sony Alpha ILCE-6000 Screen Replacement
Cosa ti serve
  1. Sony Alpha ILCE-6000 Screen Replacement, Battery Replacement: passo 1, immagine 1 di 1
    • Turn off the camera by sliding the power switch to OFF.
  2. Sony Alpha ILCE-6000 Screen Replacement: passo 2, immagine 1 di 3 Sony Alpha ILCE-6000 Screen Replacement: passo 2, immagine 2 di 3 Sony Alpha ILCE-6000 Screen Replacement: passo 2, immagine 3 di 3
    • Flip the camera upside down and locate the battery compartment.
    • Slide the compartment lock to OPEN to unlock it.
  3. Sony Alpha ILCE-6000 Screen Replacement: passo 3, immagine 1 di 2 Sony Alpha ILCE-6000 Screen Replacement: passo 3, immagine 2 di 2
    • Locate the blue lever that keeps the battery in place.
    • Push the blue lever back to release battery.
  4. Sony Alpha ILCE-6000 Screen Replacement: passo 4, immagine 1 di 1
    • Once the battery is free, you are able to take the battery out of the compartment.
  5. Sony Alpha ILCE-6000 Screen Replacement, Screen: passo 5, immagine 1 di 3 Sony Alpha ILCE-6000 Screen Replacement, Screen: passo 5, immagine 2 di 3 Sony Alpha ILCE-6000 Screen Replacement, Screen: passo 5, immagine 3 di 3
    • Flip the camera to the bottom side. Using screwdriver, remove the two screws located on the bottom of camera screen.
    • Flip the camera back over, locate the two other 3mm screws behind the screen and remove them.
    Hi how do you remove the two screws behind the LCD? It is impossible to reach with the angles that the screen can turn. thanks.
    Johnny Chen - Replica
    Hi, johnny. I encounter the same problem, did you solve it?
    imanthony1993 - Replica
    I found that if i turned the camera on its front you can access the screw on the left a bit better when the screen is turned upwards, facing the sky, if you know what i mean….but otherwise the right one i mangaged to do from going in from the top.
    hope that makes sense!
    Charlenne Woodcock - Replica
    There is a gap in the back plate when you turn the body upside down and flip the screen facing down. When you look down from above the upside down body you’ll find the screw is reachable.
    Kevin Ketelaars - Replica
  6. Sony Alpha ILCE-6000 Screen Replacement: passo 6, immagine 1 di 1
    • Gently pry open the screen backplate.
  7. Sony Alpha ILCE-6000 Screen Replacement: passo 7, immagine 1 di 2 Sony Alpha ILCE-6000 Screen Replacement: passo 7, immagine 2 di 2
    • Gently pry off the plastic cover at the top of the screen.
  8. Sony Alpha ILCE-6000 Screen Replacement: passo 8, immagine 1 di 2 Sony Alpha ILCE-6000 Screen Replacement: passo 8, immagine 2 di 2
    • Carefully remove the clip located at the top of the screen.
  9. Sony Alpha ILCE-6000 Screen Replacement: passo 9, immagine 1 di 1
    • Flip the camera so that it is bottom side up. Pry off the inner support plate.
  10. Sony Alpha ILCE-6000 Screen Replacement: passo 10, immagine 1 di 3 Sony Alpha ILCE-6000 Screen Replacement: passo 10, immagine 2 di 3 Sony Alpha ILCE-6000 Screen Replacement: passo 10, immagine 3 di 3
    • Gently wiggle the screen's ribbon cable until it comes free from the white slot.
    Does the black connector open like the the whit one by lifting the black part?
    Christopher St.Louis - Replica
    No the small cable just slides in and out kept in with friction rather than a lever.
    Kevin Ketelaars -
  11. Sony Alpha ILCE-6000 Screen Replacement: passo 11, immagine 1 di 1
    • Pry apart the metal backplate and remove it.
  12. Sony Alpha ILCE-6000 Screen Replacement: passo 12, immagine 1 di 2 Sony Alpha ILCE-6000 Screen Replacement: passo 12, immagine 2 di 2
    • Gently remove the old screen, and replace it with the new one.
Conclusione
Altre 6 persone hanno completato questa guida.
Tony Au
Membro da: 02/02/17
360 Reputazione
2 Guide realizzate
UW Tacoma, Team 1-4, Rose Winter 2017 Membro di UW Tacoma, Team 1-4, Rose Winter 2017
UWT-ROSE-W17S1G4
4 Membri
10 Guide realizzate
4 Commenti
This is super helpful! Where did you purchase your replacement part from?
Claire Sweet - Replica
The white connector opens by prying up the black part. What about the little black connector?
Just comes out when you pull on it gently
Kevin Ketelaars -
Top left screw on back plate is a pain to put back in at an angle with magnetized JIS driver. Non magnetized or slightly loose fitting driver might help.
Trick is to get the screw fit in the thread at the right angle, then drive it in with the driver at an angle.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 114
Tutti i Tempi: 10,411
