Salta al contenuto principale
Sony Alpha ILCE-6000 Lens Replacement
Cosa ti serve
  1. Sony Alpha ILCE-6000 Lens Replacement, Lens: passo 1, immagine 1 di 1
    • Turn of camera by turning the switch to OFF.
  2. Sony Alpha ILCE-6000 Lens Replacement: passo 2, immagine 1 di 1
    • Use the finger, press and hold the release black circle button ( on the bottom ) next to the lens on the front of the camera.
  3. Sony Alpha ILCE-6000 Lens Replacement: passo 3, immagine 1 di 2 Sony Alpha ILCE-6000 Lens Replacement: passo 3, immagine 2 di 2
    • Using the left hand or the right hand to hold the camera body, other hand twist the lens counterclockwise and pull it off.
    • Align the white dot of the lens to the white dot on the camera mount to completely replace.
Conclusione
Vuong Nguyen
Membro da: 02/02/17
122 Reputazione
1 Guida realizzata
UW Tacoma, Team 1-4, Rose Winter 2017 Membro di UW Tacoma, Team 1-4, Rose Winter 2017
UWT-ROSE-W17S1G4
4 Membri
10 Guide realizzate
Un commento
my camera will not recognize my lens, optical steady shot 1650. it used to work fine, but I dropped it. now the camera says it's not attached properly. any suggestions?
Connie - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 37
Tutti i Tempi: 1,955
