Salta al contenuto principale
Sony Alpha ILCE-6000 Lens Contact mount Replacement
Cosa ti serve
  1. Sony Alpha ILCE-6000 Lens Contact mount Replacement, Lens Contact mount: passo 1, immagine 1 di 2 Sony Alpha ILCE-6000 Lens Contact mount Replacement, Lens Contact mount: passo 1, immagine 2 di 2
    • Use the finger, press and hold the release black circle button ( on the bottom ) next to the lens on the front of the camera. Twist the lens counterclockwise and pull it off.
  2. Sony Alpha ILCE-6000 Lens Contact mount Replacement: passo 2, immagine 1 di 2 Sony Alpha ILCE-6000 Lens Contact mount Replacement: passo 2, immagine 2 di 2
    • Locate and remove the four 5mm screws at the four corners.
  3. Sony Alpha ILCE-6000 Lens Contact mount Replacement: passo 3, immagine 1 di 1
    • Use two fingers to gently remove surface metal pieces out of frame. Be aware of the ribbon cable connecting the mount to the board below.
  4. Sony Alpha ILCE-6000 Lens Contact mount Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Carefully pull out the ribbon cable from the connector on the lens board. Then follow these instructions in reverse order to reassemble the lens.
    • The ribbon cable can easily be damaged or punctured by a sharp pair of tweezers. Be gentle.
Conclusione
Tony Au
Membro da: 02/02/17
360 Reputazione
2 Guide realizzate
UW Tacoma, Team 1-4, Rose Winter 2017 Membro di UW Tacoma, Team 1-4, Rose Winter 2017
UWT-ROSE-W17S1G4
4 Membri
10 Guide realizzate
2 Commenti
Not very helpful. You should at least tell people how to diagnose that it is indeed the the mount that is the problem and not the camera body, and where to get the replacement parts,
BTW, before I would try repairing the camera yourself or sending it out for repair there is a simple thing to try first, cleaning the contacts on camera body and back of lens. A simple back and forth wiping with a clean lintless cloth, like a microfiber lens cleaning cloth, often will solve the problem. Also gently rubbing the contacts with a clean pencil eraser can help, but these erasers can leave a thin oily film behind so wipe contacts afterwards. A tiny amount of zero residue contact cleaner on a cotton swab, just enough to dampen it, would work as well.
rwjj99 - Replica
I had message lens not detected. Using this guide i fixed it. Just reconnected all cables inside and cleaned with alcohol
Thanks!
Alexsey Novik - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 28
Tutti i Tempi: 1,905
