Salta al contenuto principale
Sony Alpha ILCE-6000 E-mount Replacement
Cosa ti serve
  1. Sony Alpha ILCE-6000 E-mount Replacement, Lens: passo 1, immagine 1 di 1
    • Turn of camera by turning the switch to OFF.
  2. Sony Alpha ILCE-6000 E-mount Replacement: passo 2, immagine 1 di 1
    • Use the finger, press and hold the release black circle button ( on the bottom ) next to the lens on the front of the camera.
  3. Sony Alpha ILCE-6000 E-mount Replacement: passo 3, immagine 1 di 2 Sony Alpha ILCE-6000 E-mount Replacement: passo 3, immagine 2 di 2
    • Using the left hand or the right hand to hold the camera body, other hand twist the lens counterclockwise and pull it off.
    • Align the white dot of the lens to the white dot on the camera mount to completely replace.
  4. Sony Alpha ILCE-6000 E-mount Replacement, E-mount Replacement: passo 4, immagine 1 di 2 Sony Alpha ILCE-6000 E-mount Replacement, E-mount Replacement: passo 4, immagine 2 di 2
    • Locate the E-mount on the front of the camera
  5. Sony Alpha ILCE-6000 E-mount Replacement: passo 5, immagine 1 di 3 Sony Alpha ILCE-6000 E-mount Replacement: passo 5, immagine 2 di 3 Sony Alpha ILCE-6000 E-mount Replacement: passo 5, immagine 3 di 3
    • Take a Philips head 00 screw to remove the four of the 5.1mm screws located on the E-mount.
  6. Sony Alpha ILCE-6000 E-mount Replacement: passo 6, immagine 1 di 3 Sony Alpha ILCE-6000 E-mount Replacement: passo 6, immagine 2 di 3 Sony Alpha ILCE-6000 E-mount Replacement: passo 6, immagine 3 di 3
    • After removing the screws, pull off the E-mount metal ring gently and wiggle it until its free.
    • Remove the plastic ring located under the metal ring.
    • Do not remove the metal piece that is located behind the plastic ring.
  7. Sony Alpha ILCE-6000 E-mount Replacement: passo 7, immagine 1 di 1
    • Replace the plastic E-mount ring with a new one.
Conclusione
Yirga Yilma
Membro da: 02/02/17
221 Reputazione
2 Guide realizzate
UW Tacoma, Team 1-4, Rose Winter 2017 Membro di UW Tacoma, Team 1-4, Rose Winter 2017
UWT-ROSE-W17S1G4
4 Membri
10 Guide realizzate
2 Commenti
Hello folks,
actually I have to replace the E-mount ring my ILCE-6000, which seems very easy with this description. Thanks a lot for this!
Is the ring available anywhere on this globe? I would truly appreciate any hint.
Best regards, JDK
JDK - Replica
Hi there, found a source for the ring as original part. The price is reasonable. Now waiting for delivery ...
Best regards, JDK
JDK - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 65
Tutti i Tempi: 3,792
