Salta al contenuto principale
Sony Alpha DSLR- A850 Viewfinder Window Replacement
Cosa ti serve
  1. Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Cover: passo 1, immagine 1 di 1
    • Find the rubber viewfinder cover on the upper rear of the camera, above the view screen.
  2. Sony Alpha DSLR- A850 Viewfinder Window Replacement: passo 2, immagine 1 di 1
    • Slide the rubber piece off.
    • There may be a slight popping sound.
  3. Sony Alpha DSLR- A850 Viewfinder Window Replacement: passo 3, immagine 1 di 1
    • Once the rubber piece has been removed, inspect the area.
    • If everything looks fine, go ahead and slide the new rubber piece on the same way the old piece was slipped off.
  4. Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Window: passo 4, immagine 1 di 2 Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Window: passo 4, immagine 2 di 2
    • Remove all four screws from the viewfinder.
  5. Sony Alpha DSLR- A850 Viewfinder Window Replacement: passo 5, immagine 1 di 2 Sony Alpha DSLR- A850 Viewfinder Window Replacement: passo 5, immagine 2 di 2
    • Grasp the side of the window with either a set of tweezers or your fingers. Lift upwards and slightly towards the base of the camera.
  6. Sony Alpha DSLR- A850 Viewfinder Window Replacement: passo 6, immagine 1 di 1
    • To reinsert the window, push inward and slightly forward. There is a tab on the camera that the window must catch on in order to be put into place.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 384
