Salta al contenuto principale
Sony Alpha DSLR- A850 Focus lens Replacement
Cosa ti serve
  1. Sony Alpha DSLR- A850 Focus lens Replacement, Focus lens: passo 1, immagine 1 di 3 Sony Alpha DSLR- A850 Focus lens Replacement, Focus lens: passo 1, immagine 2 di 3 Sony Alpha DSLR- A850 Focus lens Replacement, Focus lens: passo 1, immagine 3 di 3
    • Push in the button next to the lens.
    • While holding the button twist the lens counter-clockwise.
    • Pull up and remove lens from camera.
  2. Sony Alpha DSLR- A850 Focus lens Replacement: passo 2, immagine 1 di 3 Sony Alpha DSLR- A850 Focus lens Replacement: passo 2, immagine 2 di 3 Sony Alpha DSLR- A850 Focus lens Replacement: passo 2, immagine 3 di 3
    • Inside toward the top you will find a small slit in the plastic piece.
    • Insert a flat head screw driver into the slit and pull down to access the focus lens.
  3. Sony Alpha DSLR- A850 Focus lens Replacement: passo 3, immagine 1 di 3 Sony Alpha DSLR- A850 Focus lens Replacement: passo 3, immagine 2 di 3 Sony Alpha DSLR- A850 Focus lens Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers grab the focus lens on the side by the two tabs that are on it.
    • Do not grab the focus lens in the middle as this will damage the lens.
    • Pull out and remove focus lens from camera.
  4. Sony Alpha DSLR- A850 Focus lens Replacement: passo 4, immagine 1 di 3 Sony Alpha DSLR- A850 Focus lens Replacement: passo 4, immagine 2 di 3 Sony Alpha DSLR- A850 Focus lens Replacement: passo 4, immagine 3 di 3
    • When inserting new focus make sure to orient it where the two tabs are facing towards you with the smaller tab facing up.
    • Angle the focus lens to make installation easier.
    • Lay the new focus lens into the plastic tray.
    • It does not snap into place.
  5. Sony Alpha DSLR- A850 Focus lens Replacement: passo 5, immagine 1 di 2 Sony Alpha DSLR- A850 Focus lens Replacement: passo 5, immagine 2 di 2
    • Insert screw driver into the slit and push up to close.
    • You can also use your thumb, if you are careful not to touch the lens as this could leave a smudge on the lens.
    • You will hear a click when the plastic tray is back in place.
  6. Sony Alpha DSLR- A850 Focus lens Replacement: passo 6, immagine 1 di 2 Sony Alpha DSLR- A850 Focus lens Replacement: passo 6, immagine 2 di 2
    • When re-installing the lens line up the orange dots that are one both lens and camera.
    • Fit lens into place and turn clockwise to secure it back to camera.
Conclusione
You have now completed a focus lens replacement.
Walter Littlefield
Membro da: 03/21/18
265 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 744
