Salta al contenuto principale
Sony Alpha A350 Front Case Replacement
Cosa ti serve
  1. Sony Alpha A350 Front Case Replacement, Front Case: passo 1, immagine 1 di 2 Sony Alpha A350 Front Case Replacement, Front Case: passo 1, immagine 2 di 2
    • Using a Phillips #00 Screwdriver, remove the four 5.5mm screws from the bottom of the camera.
    • Using a Phillips #00 Screwdriver, remove the one 4.3mm screw.
  2. Sony Alpha A350 Front Case Replacement: passo 2, immagine 1 di 2 Sony Alpha A350 Front Case Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove one 3.6mm screw on the left side of the camera.
    • Open the remote / DC under the rubber flap to reveal a screw.
    • Using the Phillips #00 screwdriver, remove one 4.3mm screw.
  3. Sony Alpha A350 Front Case Replacement: passo 3, immagine 1 di 2 Sony Alpha A350 Front Case Replacement: passo 3, immagine 2 di 2
    • Open the flash on the top of the camera and remove two 4.3mm screws with a Phillips #00 screwdriver.
    • If the spring guard falls out during deconstruction, gently place the guard over the spring during construction.
    • To open the flash, simply press the button on the left side.
  4. Sony Alpha A350 Front Case Replacement: passo 4, immagine 1 di 2 Sony Alpha A350 Front Case Replacement: passo 4, immagine 2 di 2
    • Open the plastic SD card door.
    • Using Phillips #00 screwdriver, remove two 4.4 mm screws outside and two 4.4mm screws inside the door.
  5. Sony Alpha A350 Front Case Replacement: passo 5, immagine 1 di 2 Sony Alpha A350 Front Case Replacement: passo 5, immagine 2 di 2
    • Gently pull the outer front case from the camera.
    • It should fall apart easily if all screws are removed.
Conclusione
IUPUI, Team S1-G6, Henning Fall 2019 Membro di IUPUI, Team S1-G6, Henning Fall 2019
IUPUI-HENNING-F19S1G6
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 724
