Salta al contenuto principale
Sony Alpha A3000 Motherboard Replacement
Cosa ti serve
  1. Sony Alpha A3000 Motherboard Replacement, Rear Case: passo 1, immagine 1 di 3 Sony Alpha A3000 Motherboard Replacement, Rear Case: passo 1, immagine 2 di 3 Sony Alpha A3000 Motherboard Replacement, Rear Case: passo 1, immagine 3 di 3
    • Remove the seven highlighted screws shown here.
    • Screws are teeny tiny, don't lose them!
  2. Sony Alpha A3000 Motherboard Replacement: passo 2, immagine 1 di 2 Sony Alpha A3000 Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove this final screw from the memory card compartment.
    • Remove the chassis by pulling the back cover away from the camera.
    • Be careful not to damage any of the delicate ribbon cables when removing the chassis.
  3. Sony Alpha A3000 Motherboard Replacement: passo 3, immagine 1 di 2 Sony Alpha A3000 Motherboard Replacement: passo 3, immagine 2 di 2
    • Gently but forcefully lift up on the parallel cable connecting the two halves of the camera.
  4. Sony Alpha A3000 Motherboard Replacement, Motherboard: passo 4, immagine 1 di 2 Sony Alpha A3000 Motherboard Replacement, Motherboard: passo 4, immagine 2 di 2
    • After removing the backing from the camera. Remove the two final screws in the memory compartment area.
    • Detach the facing for the memory dock.
  5. Sony Alpha A3000 Motherboard Replacement: passo 5, immagine 1 di 2 Sony Alpha A3000 Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove the eight screws securing the mount for the flash device.
  6. Sony Alpha A3000 Motherboard Replacement: passo 6, immagine 1 di 2 Sony Alpha A3000 Motherboard Replacement: passo 6, immagine 2 di 2
    • Remove the three remaining screws holding in the protective metal casing.
  7. Sony Alpha A3000 Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the metal casing.
  8. Sony Alpha A3000 Motherboard Replacement: passo 8, immagine 1 di 1
    • Remove three screws holding down the motherboard .
  9. Sony Alpha A3000 Motherboard Replacement: passo 9, immagine 1 di 2 Sony Alpha A3000 Motherboard Replacement: passo 9, immagine 2 di 2
    • Detach the nine serial cables connecting it to the camera body.
  10. Sony Alpha A3000 Motherboard Replacement: passo 10, immagine 1 di 1
    • Finally remove the motherboard from the casing.
Conclusione
Altre 6 persone hanno completato questa guida.
USF Tampa, Team 4-4, Meier Fall 2015 Membro di USF Tampa, Team 4-4, Meier Fall 2015
USFT-MEIER-F15S4G4
4 Membri
10 Guide realizzate
Un commento
Then loose the plug all the motherboard?
kongre172 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 22
Tutti i Tempi: 2,357
