Salta al contenuto principale
Sony Alpha 6000 Shutter Button Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Sony Alpha 6000 Shutter Button Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the camera is turned off by turning the switch to OFF.
  2. Sony Alpha 6000 Shutter Button Replacement: passo 2, immagine 1 di 1
    • Flip the camera around to access the battery compartment.
    • Slide the battery compartment lock to the left to unlock it.
  3. Sony Alpha 6000 Shutter Button Replacement: passo 3, immagine 1 di 1
    • Locate the blue latch that holds the battery in.
  4. Sony Alpha 6000 Shutter Button Replacement: passo 4, immagine 1 di 1
    • Push the latch back to release battery.
  5. Sony Alpha 6000 Shutter Button Replacement: passo 5, immagine 1 di 1
    • The battery can now be taken out of its compartment.
  6. Sony Alpha 6000 Shutter Button Replacement, Back Cover: passo 6, immagine 1 di 1
    • Turn the camera upside down and unscrew these two bottom 6 mm screws located on either side of the body by using the J00 head screw.
  7. Sony Alpha 6000 Shutter Button Replacement: passo 7, immagine 1 di 1
    • Turn the camera sideways.
    • Open the mini HDMI compartment and locate the two 6 mm screw underneath and another to the right of the compartment.
    • Unscrew using the J00 head screw.
  8. Sony Alpha 6000 Shutter Button Replacement: passo 8, immagine 1 di 1
    • Locate the two 4 mm screws within the battery compartment and unscrew them using the J00 screw head.
  9. Sony Alpha 6000 Shutter Button Replacement: passo 9, immagine 1 di 1
    • Bend the camera's screen forward to uncover two 3 mm screws below the eyepiece.
    • Locate them and unscrew them.
  10. Sony Alpha 6000 Shutter Button Replacement: passo 10, immagine 1 di 2 Sony Alpha 6000 Shutter Button Replacement: passo 10, immagine 2 di 2
    • Use a plastic opening tool around the body of the camera to wedge the back cover off. Start from the bottom next to the battery compartment.
    • If necessary, lightly use your hand to pull the the back cover down to completely remove it.
  11. Sony Alpha 6000 Shutter Button Replacement, Shutter Button: passo 11, immagine 1 di 1
    • Once the back cover is off, locate the flash of the camera and push it forward to open it
  12. Sony Alpha 6000 Shutter Button Replacement: passo 12, immagine 1 di 1
    • Locate the two 3 mm screws within the flash and unscrew them
  13. Sony Alpha 6000 Shutter Button Replacement: passo 13, immagine 1 di 1
    • Hold the camera from the bottom and using a spudger, go around the top of the camera and separate the top plastic piece from the main body.
  14. Sony Alpha 6000 Shutter Button Replacement: passo 14, immagine 1 di 2 Sony Alpha 6000 Shutter Button Replacement: passo 14, immagine 2 di 2
    • Hold the top of the camera away from the body.
    • Carefully turn it over to uncover the bottom of the shutter button.
  15. Sony Alpha 6000 Shutter Button Replacement: passo 15, immagine 1 di 1
    • Locate the two screws holding the shutter button and unscrew them.
  16. Sony Alpha 6000 Shutter Button Replacement: passo 16, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Once the screws are out, use a pair of tweezers to pull out the circular metal piece under the shutter button.
  17. Sony Alpha 6000 Shutter Button Replacement: passo 17, immagine 1 di 1
    • Turn the top plastic piece back over.
    • Now you will be able to completely remove the camera's shutter button.
Conclusione
Now that the shutter button is removed, you will be able to replace it with a new piece. To reassemble your device, follow these instructions in reverse order.
Altre 6 persone hanno completato questa guida.
USF Tampa, Team 4-5, Passmore Fall 2016 Membro di USF Tampa, Team 4-5, Passmore Fall 2016
USFT-PASSMORE-F16S4G5
3 Membri
12 Guide realizzate
4Commenti sulla guida
Check also https://www.youtube.com/watch?v=y3CCJtD0...
You don't need to remove the back cover (and don't try it because first, you need to remove the top cover...)
Philippe Combronde - Replica
Where can i buy a replacement button?
Simon Lundh - Replica
You can find the flexible cable with the shutter button on aliexpress:
https://www.aliexpress.com/store/product...
Lac Uster -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 168
Tutti i Tempi: 18,805
