Salta al contenuto principale
Sony Alpha 5100 Lens Replacement
  1. Sony Alpha 5100 Lens Replacement, Lens: passo 1, immagine 1 di 1
    • Place the camera in front so the lens is facing you. There should be a small button on the bottom left side of the lens.
  2. Sony Alpha 5100 Lens Replacement: passo 2, immagine 1 di 1
    • While holding down the button with your left thumb, use your right hand to twist the lens counterclockwise.
    • Make sure that you are twisting the bottom end of the lens.
  3. Sony Alpha 5100 Lens Replacement: passo 3, immagine 1 di 1
    • To insert a new lens, align the marking on the lens to the marking on the mount on the camera body.
    • Once insert correctly, you can twist the lens in clockwise direction easily until it clicks.
Conclusione
Quang Phan
Membro da: 10/30/19
97 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 30
Tutti i Tempi: 914
