Salta al contenuto principale
Sony Action Cam Mini HDR-AZ1 Protective Doors Replacement
  1. Sony Action Cam Mini HDR-AZ1 Protective Doors Replacement, Protective Doors: passo 1, immagine 1 di 1
    • Pull on the port door until it opens.
  2. Sony Action Cam Mini HDR-AZ1 Protective Doors Replacement: passo 2, immagine 1 di 1
    • Grasp the door and pull straight out. Don't worry, this will not break it.
  3. Sony Action Cam Mini HDR-AZ1 Protective Doors Replacement: passo 3, immagine 1 di 1
    • The door should pop out.
Conclusione
To remove the SD card dust door, follow these exact steps. To reassemble your device, follow these instructions in reverse order.
UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 Membro di UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G7
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 281
